Sump Plug Thread
Bayliner175xt
Hi can anyone tell me what thread a 2003 Mercruiser 135 HP, sump plug is.
Thanks
Robbabob
Re: Sump Plug Thread
Think it will left handed threads for you down under :p:D
Just kidding! try the search function maybe... there might be an answer somewhere in the forum already :)
Good luck!
:cool:
When you say sump, do you mean oil pump pickup in the oil pan, bilge pump, block plug or some other component?
Ayuh,... If you mean the oil drain plug on the oil pan, it'll be the metric equilivant to a 1/2" fine inch thread....
You mean 13mm :D
