Suzuki Cooling Issue
raz.c
Hi, My 1988 Suzuki DT115 pisses strong until boat gets up on plane at high RPMs. I recently installed planing fins, i may take them off, but would still like to get up on a plane without overheating. New Impeller installed and pees fine until planing off.
-Thanks in Advance
duck0872
Re: Suzuki Cooling Issue
check the thermostat. I may be wrong but I seem to remember reading that as long as the impeller is working it will pee regardless as to whether the thermostat opens or not
99yam40
Could be sucking air if planning fins cause too much turbulence around intake or raises intake too high
