swap 2.5 omc for 3.0 merc
Phantom17
I have a 1981 omc GM 2.5 in good shape. I want to put it into a stingray with an 85 GM merc 3.0. Is this the same block? I know I need to change over exhaust / intake, muonts etc, but will the block line up with all the right holes in all the right places? Just making sure. Thanks
Laddies
Banned
Re: swap 2.5 omc for 3.0 merc
Even though the blocks are differant every thing will interchange the carb may need to be rejetted
Phantom17
the blocka are different?!?!?!?! I've been told they're the same, and I'd need to change the manifolds, because those are not. Enlighten me, please!
Phantom17
I will be using the 2.5 block, and the carb, intake / exhaust, riser etc from the 3.0........... just to be clear.
Laddies
Banned
The 2.5 is 153 cu.in and the 3.0 is 181 cu.in a larger bore the 2.5 has no harmonic balancer and is internal balanced and the 3.0 has harmonic balancer other than that they are the same block on the outside
Ayuh,........<br /><br />If you're talking about putting a 2.5l OMC , GM block in place of a 3.0l Mercruiser, GM block ,......<br />No Problem,..... All the Holes are Right where they Belong,.............<br /><br />Any other GM 2.5l motors are Totally Different..............
Phantom17
Thanks bondo, btw, you mentioned the epoxy on the 3.0, know of/ heard of any good places in the Boston area?
