Swapping from an interchangeable hub to a fixed rubber hub prop?
viperbluelx
OK, I'm a newbie so be easy on me. My 05 Stingray 185LX has a Michigan Wheel 14.5" x 19P prop with an interchangeable hub. I ran up on a sandbar and bent the prop so I just ordered a Solas prop but it says it comes with a fixed rubber hub. Will this still be a simple swap? Unbolt the old prop slide everything off and slide on the new one and torque to spec? Thanks.
Re: Swapping from an interchangeable hub to a fixed rubber hub prop?
Ayuh,... You'll need the thrust hub, 'n hardware kit for it...
They're probably different...
