Swapping out chevy 350 for GMC Detroit 6.5L Diesel
surferguy001
I found an add on craigslist. some guy bought three of these GMC diesels as a package deal from the military. Idk much about engines, but i do know there are marine grade and non marine grade engine parts added to the original block. This guy told me the engine came off of a Hummer, and the year is about 1988, so idk if its ok to use? Also, how much would a transom assembly and sterndrive package cost for this engine, if the engines worth it? He is selling it for $900, and im just excited cause i know diesels last way longer than gas engines. Any response is super appreciated.
O, my chevy 350 had like 1in of clearence above it in the engine compartment, would this engine even fit?
surferguy001
Re: Swapping chevy 350 for GMC Detroit 6.5L Diesel
And aslo, would i be able to convert the gas tank over to diesel too?
Thanks!
Nope....
elkhunter338
Re: Swapping out chevy 350 for GMC Detroit 6.5L Diesel
If those are the same chevy diesels they put in the truck, which coming out of a hummer I think they are I would not touch it for a boat engine.
Stick with your chevy 350 and you will be happy.
TilliamWe
Banned
A naturally aspirated 6.5 diesel would be an absolute PIG in a boat. Your 350 is better in EVERY way. And it won't fit, and even if it did, you would be sorry.
zbnutcase
Why would anyone swap out a great engine for one of the WORST ever made?????
surferguy001
the 350 is rusted all the way through the entire block, and obviously has to be replaced..
You haven't even mentioned what outdrive you have. It may not even be able to handle a diesel engine. Besides, even if it was a good engine, the cost would be way more than you think to make a diesel marine ready and hookup to an outdrive.
A new 350 engine is what you need, along with a closed cooling system.
surferguy001
i dont know what outdrive i had because it was COMPLETELY corroded from saltwater (think alpha 1.) It was so corroded that nothing was left basically. So i had to remove it with a sledgehammer, believe it or not, and now i need to replace everything having to do with the engine/stern. Here is a photo of the corrosion...
http://s789.photobucket.com/albums/yy173/surferguy001/Boat/?action=view&current=IMG_0473-1.jpg
elkhunter338
I see lack of tlc, I see those outdrives covered with stuff as I walk along the docks and it is a shame to see what looks like a good boat going to waste. Yep you need a whole new setup. Might as well buy a complete engine/outdrive combo for that repair.
I wonder if the transom is solid or if it is soft?
Ever think of converting it to out boards with a off shore bracket?
surferguy001
Its a project boat, and the corrosion came with it Lol. I already checked the outdrive by drilling some test holes and its totally solid. I just need to save money at this point cause ya, i know i need a whole new package. Huh, i didn't know i would be able to put outboards on it. I don't really want them cause they'd get in the way of the swim deck, bait tank, and trolling lines though. Aren't they way more expensive too!?
HT32BSX115
Well, you could probably make it work. There is a company that does marinize the 6.5L engine.
http://www.peninsulardiesel.com/WP-PENTEST/?page_id=232
The one above is rated at 340HP and would require a diesel type Bravo I/II/III drive and Bravo Gimbal etc......
It's about the same size as a 454 BBC engine.
If you only have 1" above your SBC, you would probably have to seriously re "do" the deck over the engine to make it all fit. It also would weigh a LOT more than your SBC (about the same as a 454)
It would however, cost a fortune.
Um.....ANY naturally aspirated diesel is a PIG in any thing it's in!!
I bought one brand new in a 94 GMC and I still have it. At almost 190,000 miles.....It still runs just fine and it pulls my 21ft Fourwinns just fine too......I think "Worst Ever Made" might be somewhat of an exaggeration.......
Your best bet might be to find yourself a newer SBC V-8 (MPI) with maybe a Bravo III or a Volvo Penta DP type drive......
Regards,
Rick
Fireman431
That is quite a project you've gotten yourself into. Your best bet might be to find a boat with soft floors & transom just for the powertrain combo. Just swap them out together and discard the old engine/outdrive.
I noticed the registration sticker from 2001. That boat hasn't been floated in 10 years?
QC
Hey guys . . . OP has not been back since September. Maybe he'll resurface, or maybe he decided against this ;)
HT32BSX115
I just LOVE these OLD threads!! :rolleyes:
