Synch gear & throtlle cable 60hp 1992 3 cyl
Davee3
Is there no search function here? Looking for info on cable reinstall or at least info on timing advance vs gear cable selecting gear
I would think the timing moves first along with the throttle cam , then gear gets selected. Now how adjusted ? The manual I have (Seloc) is poor for this model
?????-The gearshift cable moves first.-------After motor is in gear the timing advances and throttle is opened a little later.-------Make no adjustment untill you are sure of what you are doing !
