Synthetic Transmission Oil = Synthetic 75W90?
Saline Marina
Checking the iboats VP site for lubes and I don't see the 75W90 listed but instead "Synthetic Transmission Oil" which is API GL-5 rated but doesn't say anything about the viscosity.
Can anyone clarify if this is the right stuff?
Thanks
You have a link?
There are 2 viscosity available so you have to select which one.
If you zoom in on one of the pictures, it says 75w-140 so not the correct lube. May need to call to make sure.
The part number of 1141679 is correct though!
I have found that buying this on the net is not cost effective. Shipping kills any savings. For 2 of these shipping to me is $11
I always buy by the gallon so shipping on that is $8. May be worth it if you buy it that way.
Saline Marina
THanks, yes I was considering a larger volume to save shipping since I will need it in the future and I wouldn't think it would go bad :)
It takes around 1/2 gallon so I always have another one handy. My pump screws right into the container.
