tach jumping
spectrum
when cruising in a 1988 sprectrum with the pinto 2.3 the tach jumps 200-300 rpms all the time. but the boat sounds healthy ( for a pinto) :D do i need new points and condenser. i just put in new spark plugs or is this just a boat thing
JustJason
Re: tach jumping
it could be a bad tach... but its more likely its a bad tach wire/crimps....
ziggy
Re: tach jumping
yep, along with cap and rotor too...... tune up parts are once a year replacements if ya want yer rig to run as well as it can..... along with dwell and time it....
spectrum
Re: tach jumping
thank you for your help captjason and ziggy . this is my first boat and it is quite a learning curve.but this site has alot of info and helpful people thanks again.
watermellonI
Re: tach jumping
I had a similar prob with my tach, I moved the switch on the back and then moved it back to it s original position, old tach, I think there was some corrosion in it, and yep, I know I need a new one,
