Tach
Ironmike
I am working on an old boat, 16ft alum with home made casting decks etc. original merc sized up & have replaced with an old omc 1968 55hp trl-10 is there anything i should be checking before trying to connect the tach. There is a grey wire comming from power pac that i think goes to tach. just not sure if anything different between this omc & merc that was on the boat. just want to make sure i do not hurt the power pack.
dolluper
Re: Tach
from terminal block #7 two away from attch screw gray running to control box gray at control box to tach don't forget your ground
