tachometer reading off??
ralphl
installed new guages in my pontoon with a 55 hp Suzuki 2st (1997) All working fine and motor runs great but the tach only reads about 1500 at wide open. About what should it read, Could I have set the tach switch to the wrong position? I set it at 6.
ralphl
Re: tachometer reading off??
thanks, apparently 6 is correct. What rpm should I see (approx) at wide open??
99yam40
My guess would be around 5500, but I do not have a manual on it
