tap size for shift cable nut?
gabe1
Hello
The shift cable nut in the bell housing (1988 Alpha One)
Is shoot, it looks like it has been there for a long time.
The "special" socket striped the brass nut, I cut the cable
and so far I drilled a 5/16 hole thru it.
Does anyone know the TAP size for this tread?
Thanks
Happy holidays
Bt Doctur
Re: tap size for shift cable nut?
I use a 1/4 NPT that was shortened by gringing away the larger portion of the threads.
gabe1
1/4 NPT sounds small for this hole?
Did you use it on a 1988 Alpha One?
gabe1
Thanks for the help guys
I have 2 posts now with 2 diferent typs of Tap
A 1/4 NPT which is a pipe tap?
and a 1/4-18 NPSF which is a straight tap?
I know Don is always right but why would anyone use a NTP tap?
THE BEEF
Listen to Don S.
A taper thread will lock up after a few threads.
I didn't just type that up from memory, it's actually a picture out of the service manual.
Read what it says, it doesn't say anything about an NPT, it calls out specifically a straight thread tap, and in the last paragraph says NEVER use a tapered thread tap. which is NPT.
DHPMARINE
NPSF = National Pipe Straight Fine as I recall.
DHP
gabe1
Ahh plenty of feedback now.
Don I never doubt your input and yes I know what a PDF file looks like but Bt Doctur posted an NPT tap and that’s a taper tab. I was just trying to get more info out of him.
NPSF and NPT are 2 different taps; out of curiosity I was just wondering how you could use an npt without damaging the bell housing.
Happy Holidays
Gabriel
