Test a gps/fishfinder out of the boat
sightsrv
Its here am sure but cant find. Most likley even know how
but get brain farts. How do you test these outside the boat?
Just to see if they power up. 6 volt? Put a fuse on power wire?
Have several of these and know can sit in the house and do
it but am kinda stumped. Or dumb in old age, not sure which.:confused:
NYBo
Re: Test a gps/fishfinder out of the boat
Why would it be 6V? Just connect the power leads to a 12V DC power source, observing proper polarity. If the unit has an internal GPS antenna, the GPS function should work.
UncleWillie
+1 ^^
Any 12v battery will work.
Do NOT hook it up Backwards.
If you put the palm of your hand flat on the bottom of the transducer you can very lightly feel the sonar as it pulses.
Point it sideways in a full bathtub and you may get it to report a 3-5 foot depth.
sightsrv
Didnt know what type.Bought a lcr 4x6 on ebay was new. Yep it was new.
He took it out for pictures and powered it up in his bedroom. Asked how he
did it but never heard back from him.. Understand now. Thanks much!!!
sightsrv
Uncle I guess you knew that was next. No joke it was!!!!
Have 6 of these things new to used. That lcr4x6 is new,
has transducer, wiring..etc..Cant thank you guys enough!
Thats great!! Thank you guys very much!!!!!!!!!!!
I use an old 120VAC -12VDC transformer that I save from a recharageable vacumn cleaner
sightsrv
:D..Got 100%..Needed that "old" i guess
