Thermostat, do I really need it?
vgiljebr
My thermostat on my 9.9 merc is old and corroded. Although it works fine, I like to see the tattle tale at all times.
I know that my engine will take longer to warm up without it, and my question is are there any other disadvantages to removing it?
Thanks
Vidar
deejaycee_2000
Re: Thermostat, do I really need it?
Yes, your engine can cold seize .... the thermostat regulates the cooling past the cylinders, if that area coolsdown too much and the piston runs at a different temperature the cylinder can crack and cause your motor to cold seize .... hope I have the story right there .... anyway ... replace the thermostat they aren't that expensive ... remember that it is there for a reason ....
timmathis
Yes you need it. Like said above
fishingdan
They are very inexpensive (relative to boat stuff) and easy to replace.
Texasmark
From a self proclamed smartass that thought he didn't and had to learn the hard way.
YES YOU NEED IT.
HTH,
Mark
vgiljebr
Thanks for your advice,
I replaced it today.
Vidar
If it didn't need it the manufacturer wouldn't have put it in.
jaymasta
LOL ya i could say something about that but i'll shudup
