Thermostat housing
Ok guys I have a Mercruiser 225 I'm trying to get back together. I'm about to install the engine but in need of the thermostat housing. Previous owner didnt winterize and it busted along with the old engine. I need the top piece and local marina wants $320 for it.
Re: Thermostat housing
Ayuh,...1st off,.... Resize your pictures to 480x640 or whatever Fits the page,....
Otherwise,..
You won't get many responces, because Nobody, including Myself, likes to have to Side-Scroll.....
You can probably replace the Whole Thing, buying Used on ebay, with mere pocket change.....
Looked on ebay and didnt find anything. This site wont let me upload off my computer no matter what size the pic. Those are from my photobucket page only way I could get a pic on here.
totx
225
ore
1979 SeaRay with mild 351 mercruiser V8?
cr2k
If it's a ford just wrap with bailing wire and duct tape.
Did it have the plastic balls and spring on the long outlets?
WizeOne
In Photobucket, right below the UPLOAD IMAGES & VIDEOS button, there is a line that says 'more options' in parenthesis. Click on it and it will allow you to select large-640x480. Select it and save. Henceforth, all of your uploaded pictures will display on the forum at that size.
Use CTRL to select multiple files (more options)
Pictures previously loaded will not be changed, so you may have to delete your pictures here and in photobucket and re-upload them then repaste them here.
Having to scroll to see all of the picture and the stretched out text is a real PIA.
