thermostat removal help 5.7l gm engine
hoverman
i have a 91 5.7l gm engine and went to change the thermostat because it still had the original one in it but i cant seem to get the sleeve above the thermostat out!!?? is there a trick? special tool? witch doctor dance? i have to do to get the sleeve out? by the way the sleeve looks to be brass or metal of some sort.
:eek:
Bt Doctur
Re: thermostat removal help 5.7l gm engine
grab the therm and yank, sometimes the ring must be destroyed for removal
hoverman
thanks i got it out without damaging it....:D
