Thoughts on prop scan
SkiDad
Hi Guys, i have 2 of these Michigan props - this is the prop i throw on when I'm on an unknown or shallow lake - anyhow the hub started spinning last year and I'm gonna get that changed but I also had someone scan the prop.
The prop looks very true when I spin it ...does it look close enough to leave alone ?
Its always better to have one tuned up, but from your listing, and using it only as a spare I wouldn't bother with it
SkiDad
Thanks! Yes you are right - i'm over thinking it. I definitely put some serious coin in my other prop to make it perfect.
