Thread Sealer?
Was just curious what thread sealer (if any) should I use for re-installing my block and manifold drain plugs?
Thanks in advance for the info!:)
jerryjerry05
Re: Thread Sealer?
If they were left out all winter then U might need a thread chaser to clean up the rust formed over the winter.
No sealer is needed.J
stonyloam
Re: Thread Sealer?
I know nothing of Volvo's, but Mercruiser recommends perfect seal. A good substitute for PS is Permatex (NAPA) Aviation Sealant.
Re: Thread Sealer?
Ayuh,... No sealant needed on Brass or plastic drain plugs...
