Three Blade Prop
mulliganmagic
I have a question about going from a three blade prop to a four blade prop. We have a 17.5 ft Norris Craft Bass boat with a 1986 Mercury 150 hp XR2. Currently it has a 23p three blade Quicksilver prop on it and will turn 5800 rpm. We found a loner prop from a family member to try, but it is a 26p four blade prop. We've been wanting to try a four blade prop to see what kind of performance change it gives, but I was curious if this is too much pitch for that motor and will it make it lugg too much with that high of a pitch. Do we need to find a lower pitch four blade or would it hurt to try this prop and what kind of rpms should I expect to turn?
69GlassparMan
Re: Three Blade Prop
I hear those PROPULSE adjustable pitch 4 blade props are awesome. Dont know if it would be similiar to what you are proposing.
Dhadley
Since you didnt mention what brand the 4 blade is -- its hard to say. General rule of thumb is that a 4 blade will run at a much higher X dimension than a 3. Sounds like your pretty well dialed in with the 3. Stick the 4 on and see. But dont (mis)judge all 4 blade props by this one. Not all props are created equal.
mulliganmagic
I didn't happen to look and see what brand the four blade was (I don't have it here where I can look at it). But we'll stick it on there and see what it does.
heybaylor
my 86 XR2 wont spin a 25 pitch..i/e 5000 rpm is<br />max . let alone a 26 ...good way to waste your motor..<br />The 86 XR2 is a 2.....repeat..<br /> 2 liter motor<br />23 is about as far as ya should go ...5500-6000.<br />if you want to try a 4 blade ...dunno why ?....I would use a 22 pitch...
bluewater19
Heybaylor,<br />Don't you think the size, weight, and hull type of the <br />boat should figure into how much pitch a given motor will turn?
danie
Answer to heybalor's question, a four blader turns much smoother (less vibration) and bites better (less slip) and improves holeshot when compared to a same pitch 3 blader.<br />D
heybaylor
I believe "magics" boat turns a 23 3 blade at 5800<br />That IS the hull/weight of his boat ..<br /><br />His XR2 will not turn a 26 pitch 3 or four blade at proper rpm on that boat<br /><br />Also not to get into a contest , but a 4 blade is not smoother, nor does it "not slip as much as a 3 ..<br />It does have more friction , and to turn it the same rpm as a 3 requires a lessor pitch ..<br /><br />Ask a good prop guy about pitch /rake /cup and dont forget the size/shape of the vent holes.<br />and if it is over the hub , or through the hub exhaust<br />All these come into play as to fine tuning any given hull..<br />not just pitch of the prop.<br />hmm, if more is better , how come the "high five " is now a joke
sangerwaker
Excuse me....High Five a joke? Sounds like someone is "high". :rolleyes: :p <br /><br />EDIT: Ok maybe I jumped the gun a little with my comments. The high five is an awesome prop for the right application. For heavy loads and pulling power, they cannot be beat IMO.
LubeDude
Just throw it on and see what it does. Its likely too much prop for you though.<br /><br />I am running a turbo four blade, 25P 14.25 on my 18' Bass Boat with a 2 liter 150, it runs around 60 MPH, and around 5,600 RPM. Best prop Ive ever tried. You can run the engine higher on the transom with a four blade
lyra
26 pitch 4 blades sounds like to much. You need to consider boat weight,engine height,max rpm(wot)and what you trying to get(top speed or heavy loads).
danie
heybaylor<br />You definitely missed out on some serious information along the way. You can check by means of the search facility about vibration, slip, bite (holeshot) etc regarding 3 and 4 bladers. Start with the topic "Props: 3 VS 4 Blades."<br />There is no question about a 4 blader being smoother than a two or three. I will try and obtain the links to the relevant topics and website and make a posting for your information as soon as possible. It makes very interesting reading material and contains information all boaters should know.<br />I also speak of experience from help by members of this forum like Dhadley.<br />D
danie
heybaylor<br />Information I promised is available in postings under "Outboard Non-repair Discussions; Information: Propeller types/design".<br />D
heybaylor
Damdan , I guess this is a gentlemens "agree to disagree" subject <br />I respectfully stand by my statement.
