Throttle cable bracket (91 4.3LX)
Bumperlt12
Attached is some ongoing research. I need throttle cable bracket #19 shown on fiche.
Part is no longer available and has been replaced by 805359A02, for the low low price of about $100 (!!).
I came across a part that looks identical for half the price, 805359T.
Numbers are the same except for A02 / T.
Can someone tell me if the "T" bracket will work the same as the "A02" bracket?
Alternatively, if someone MOD EDIT know where I can get one!?
Bt Doctur
that bracket is for a 4 barrel so it should fit any 4 barrel with that bolt spread
Ayuh,...... I believe one is for the Qudra-jet, that was discontinued, 'n the other is for the AFB that replaced it,.....
Never tried to swap 'em,......... but I'm bettin' I could make either of 'em work, with alittle "Tunin' ",.....
