Throttle control
That is the cold start lever. To start a carb motor, pull it up, hold the choke button (in your case, push the key in to choke) and crank the motor until she starts. As she warms up, lower the lever. The lever must be all the way down to use the throttle lever to accelerate the motor.
Rinker85
Thank you
