Throttle problems...
RAPIII
My Merc 350 will not go much higher than 2000 RPM's when in gear. When out of gear the sky's the limit anyone have any ideas??? Thanks<br />Bob
RAPIII
Re: Throttle problems...
hahah...good point. It is a 1995 Mariah Davanti it's a trailer boat. I am really confused on this one...
Nope,........<br /><br />What's your boat Bob ?????<br /><br />Dock boat or Trailer boat ???<br /><br />How High it'll Rev in Neutral has Nothing What So Ever to Do with Anything...............<br />A V8,... Running on 2 Cylinders will Rev to the Moon.............. :rolleyes:
I'd Start with the Fuel Filter........
Start with the Inexpensive Basics......<br /><br />Is it getting Fuel ?? Fuel Filters,.. Should be 2......<br />What do the Plugs Look Like ???? Change them Only if Necessary......<br />How about the Inside of the Dist. Cap ?? Corrosion ??,... Again, Change it Only if Necessary......<br /><br />How long has it been since it's Last Tune-Up ????
Also look at the ignition module. I've seen several that get water in the connecter and the terminals corrode and sometimes even corrode clear off.<br />The module and harness can be mounted either on the exhaust elbow or the distributor.
RAPIII
Thanks for all the suggestions, gonna give it all a look today.<br />Bob
