TheRussian
- Joined
- Jul 10, 2013
- Messages
- 145
Hi there, hoping someone could guide me in troubleshooting the issue with '93 4.3 LX Alpha 1 Gen 2
The boat has been running fine all season. When I took it out on the weekend the boat shifted into gear (forward and reverse) without any problems. However, while in forward gear, the throttle was very hard to push down around the half-way mark. I was still able to push it forward and the the boat would accelerate. While decreasing speed (pulling back) it appeared even tighter (REALLY tight, I was getting worried) and would not slow the engine down until some point when the engine would decelerate abruptly, jolting everyone in the boat.
I had replaced the lower shift cable about 3 years ago. I had put some grease on the sliding mechanism of the cable on top of the engine (don't know the terminology).
Any thoughts that could help me out? Hoping that I don't have to pull the boat out of water to replace the lower cable again.
Thanks in advance.
Thanks in advance.
