thunderbolt 800 carb..
inboardnewbie
I have the motor and it runs when i put fuel in the cylinders but it will only run the gas thats in it out, it will not feed itself with gas..
I put new plugs and rebuilt the fuel pump so the only thing left would be cleaning the carbs??? Is there a rebuild kit for it? The serial # is 3054534 thanks
Re: thunderbolt 800 carb..
Yes there are rebuild kits for the carbs. They are avail in lots of places. Go to the maxrules website and look up the year of that motor by serial number. The go to crowleymarine website and get carb kit numbers and google them.
Replace all gaskets, inlet needles and floats. You will need two kits.
