tilt and trim Johnson 50HP 2000
RobH1954
Ok so the tilt/trim was leaking last year out of the piston top, so I replaced the seals in the cap, and put it back on the boat filled the unit, and worked it up and down to remove air- worked fine, hooked it back up to the motor went straight to the bottom...HMMM must be a up or down release, so I replaced the up and down seals, and put in new release valves and springs ( the pieces under the 2 screw caps) worked the motor up and down ,hooked it back up to the motor, took motor off the lock perch ( has motor in UP position) drops like a rock, pump tries to lift it but wont....All I wanted was to get it to quit leaking from the cap. Ive checked the release bypass,manual valve, it is fine, I just am over looking something...BUT WHAT????
see possible video that can help. I think the single ram T&T is the same as on my etec 75
Johnson 50HP 2000​
something went south ?? doing a google on T&T repair brings up all sorts of stuff incl this. thanks for flagging it !
RobH1954
wow I thought I was having problems, well what I have done was I HALF BAKED it to begin with. It was leaking out of the top so I just replaced the seals on the piston side, and it worked BUT when I hooked it back up, the leak from the piston was gone, I Put it in place and ran the cylinder up and down and it seemed to work fine- BUT ONCE THE WEIGHT of the motor was placed on the piston (ran the pin through the unit) it dropped like a rock. SOOOO must be in the bypasses- so I bought 2 new bypass pins, and replaced the orings around the seats, took the manual bypass valve OUT of the unit and replaced the orings, PUT it back together whawhaaaa, dropped like a rock once hooked up. Soooooo I took it back off (UGHHHHH) and took the pump assembly apart and replaced the orings there- thats where Im at. OTHER than the 2 seals in the top of the piston leaking I seen NOTHING that would cause this...all the other orings in the assembly looked OK (not torn or broke) but replaced them anyways. I have it on the bench now ready to put back together,I seen NOTHING that would cause a bleed off like this, AIR in the fluid= wouldnt think so, I bleed the unit both times and it seemed to work fine- the second time I let it rest overnight then bleed it again before I hooked it up. AM I A HACK?? Starting to feel like one- worked as a mechanic for 37 years, so not world class- BUT usually not like this (lol). THE ONLY thing I havent done is remove the upper allen and lower allen on the pump galley that allows for the oil to make the piston go up and down (a allen is at the underside and on top between the pump side and the ram side) the allens wer Totally locked down and broke 2 allen sockets trying to remove them. HELP- man overboard,
RobH1954
I fill the ( pump side) to the top of the filter screen, and on the piston side about 1/2 way, attach the long bolt at bottom of mount,and run it up till it slows down or stops, then down then check fluid, then up and down until I get a full travel. I have been doing it much like a power steering on a car, a tad left a tad right, check fluid- always worked on a car-up, down up down till no foaming in the fluid.I have done this with the screw out- and with it in. It does go to full travel- its just when I put the pin in the top to connect it to the motor it wont lift it, then it will ( when I rotate the stop holding the motor, drop , and wont raise it back up. not a bit.
if all is good valving/seal ... wise is it possible the motor is incapable of producing enough PSI for the engine to go up ?
Pump side? It should all work through one hole, so I don't understand that. Also, hook it all up then do it period. Without weight, your not "purging" anything.
Does the motor and pump sound like it's cavitation when you have failure or does it quit running?
Last but not least, with the motor down...open the release screw and hand pull it up and down 3 times...after that, pull it up...safety lock it and open the fill screw and listen for air. Do that three times.
Close release screw and test.
RobH1954
I had the electric motor off the pump side. I really dont know the terminology but the pump side is the side where the oil goes in- it was easier to remove the electric motor off the top and take the unit into the garage- kept me from having to undo the wires. BTW GILLIGAN has got it going!!! I took it back off ( 3-4th time- maybe more) and rebuilt the spool (the round part in the center) I replaced the orings, and took the reliefs apart checked them, and the unit works! YEAHHHHH- other than disassembly and the orings which didnt look bad thats all I did. I filled it and started the bleed process, a little up a little down until I got full range.It seems to labor a bit going up- but it holds it position pretty good- Fish on- thanks fellas for the help! Much appreciate it
