weezzell_5400
- Joined
- Jul 25, 2012
- Messages
- 51
I just got a 1977 johnson 85 model 85ETLR77S...and it is supposed to have the tilt and trim ...but it does not ...this is a 2 part question ...A..can I swap the tilt and trim from a 1987 evinrude 120 hp model E120TXCUR....if so I believe I can figure out the logistics ....if not ..B...how do I look the motor into place so that it will not move ....have not decided which moat to put the motor on as of yet ...if it can't be swapped ill put it on a 24 foot pontoon ...if it can be swapped ill be putting it on a 1969 starcraft supersport fishing boat ....thanks for the help
