Tilt cylinder leaking fluid
bman1bpm
Just got my motor back on the boat after doing the tedious task of rebuilding my trim/tilt on a 78 chrysler 140hp. It lifts and lowers but the tilt cylinder is leaking fluid out at the top where the hydraulic line connects.
There's a metal band with a fitting on it and I think it's stripped. Is there any fix for this or is it toast? I took a picture of what I'm talking about.
Jiggz
The metal band is made of brass. You can take it off and inspect to see if it is stripped or maybe just some cleaning. You do not want to overtight this band. Tight enough only to stop leaking and no more. If it is stripped you can always order a new one it is called, cylinder band assembly and costs around $45! The part # is F2A654983
bman1bpm
Wow, I'm surprised that part is still available! I've never had much luck finding tilt/trim system parts. Mine is definitely stripped. Thanks for the part number, hopefully this will take care of the leak and get my trim system working.
jerryjerry05
Just bought one on e-bay for 25$
​They have one for 35$
Also called a banjo fitting???
bman1bpm
Ah wish I saw that, I paid $43 on eBay. Not terrible though if it fixes my leak.
