Tilt Rams
gshldon
Just wondering if i am getting water into the rams oil from a leaky seal, would i also have a leak of the oil on the shaft as well, the reason i am asking is I have water in the oil of the ram lines and nothing leaking out, and the rams are moving really slow until I disconnect the lines and push the rams in and out and water comes out of the rams and from the lines.
Thanks for the help
Re: Tilt Rams
Ayuh,... It's entirely Possible it's leaking water In, but not oil out...
