Tilt/trim and controls compatibility question
adam lancia
Would the tilt/trim and controls from a 1993 Evinrude E50TLETB be compatible with a 1988 Johnson J40TELCCS? I have the opportunity to buy a parts motor (no compression on bottom cylinder) complete with controls. My '88 is a long shaft as is the parts motor. What would be the simplest way to mate these two motors together? Thanks in advance!
Lower units and midsection are totally different.---Trim units do not interchange between these 2 motors.-----Controls with the big red plug fit any motor with the big red plug.
