Tilt trim pump will go down but not up.
css4608
I have a 2006 searay with a 4.3L. The Tilt trim pump will go down but not up, I here the relay click but do not here the pump. I tried switching the leads to the pump, I figured this would check out all the external stuff. Still it will not go up, only down(when I press the up button after switching.
Is there anything serviceable in the motor or would I need a new motor on the pump?
Bt Doctur
using a jumper from the red wire at the pump, jump the red to green (down) and red to blue(up) If the motor runs in both directions, then the relay is bad.
"Is there anything serviceable in the motor or would I need a new motor on the pump"
internal brushes, dirty armature, loose connections
