tilt/trim pump
brs517
Hi all, my question involves the trim pump on my 1986 Chaparral 178XL. There is no resevoir, oil is just added to the pump.<br /><br />My question: It's extremely difficult to determine the oil level with the black plastic dipstick. I'm wondering how much oil the system will hold. I've added some but am still barely able to read anything on the dipstick. I don't want to overfill it.<br /><br />The system seems to be working fine.<br /><br />Thanks,<br />Brian
achris
More fish than mountain goat
Re: tilt/trim pump
Please tell us what the motor is. Please include the year.
brs517
Re: tilt/trim pump
The boat's engine is a Mercruiser 3.0 4cyl. 1986. I do not know what type of electric motor is used for the trim system.
affa
Re: tilt/trim pump
Hi<br />You probably have an oildyne trimpump, if you dont see any oil on the dipstick if you clean it and put it in the hole, there is no oil, add some and check again.<br />When your done its important to screw the dipstick one turn out after it bottoms in, for ventilation.<br />Regards<br />Affa
