Tilt trim solenoid part no.
Bass-by-you
1984 mercruiser-5.0/alpha1 engine serial is 6812223 I need to replace the tilt and trim solenoids. Have been looking through the iboat data and just because I think I should be able to do it...I can't. Can anybody help me find the right part number?
Thanks
Bt Doctur
Re: Tilt trim solenoid part no.
I looked also and didnt find these.
OEM # 89-818999A2 Arco SW99 isolated base
OEM 89-96054, Arco SW54 isolated ground
OEM 89-96158 ARCO SW58 isolated ground
Bass-by-you
Bt....thanks for the feed back. But I am a little unclear about your message. Do the Arco numbers you gave me replace the O.E.M. numbers you listed? Are there 2 different part numbers for the up and down solenoids (i.e. they are not the same part?)?
Sorry I am so darn dense about this stuff.....operating out of my little box here.
Thanks
ErieRon
firmedc99
Thanks To You All, This Was Helpfull With My Predicament Aswell.
