Time to replace tires?
Kosmofreeze
Just noticed some slight weather checking on the sidewalls of my trailer tires ... 2-axle steel trailer with 7,000lb boat. I bought the rig 2 years ago. No date code on the tires - I suspect they COULD be 6-10 years old. The trailer has always been stored indoors. Tires are Firestone Transforce HT. Tread is good. I only put on about 1000 miles (<65 mph) per season.
I'm looking for a 'sign' to tell me to replace my tires. What would it be?
bajaman123
The fact you are posting this is your "sign"...you wisely are concerned about the state of your tires...so the smart move is to replace them. WHY take any chance?
Fed regulation for tires to have a date code, look on the inside. 4 digites, first 2 digit month, next 2 is year
Being the tires are HT and not ST tells me they have been replaced at least once. ST Trailer, HT Truck
ScottinAZ
first two digits are the WEEK, not the month.... :D
How big of a gambler are you ? Especially towing a 7000# boat ?
Kosmofreeze
I found my "sign" ... the date code was on the inside - 1407 😲
Pics as requested -
JimS123
If you see sidewall cracking, the tires should have been replaced several years ago. ST tires are poor to begin with. They age out before they wear out.
A good rule is to replace them every 4 years, period.
Sucks but thats life ,just had to replace mine for same reason ,tread deep enough to grow spuds in but side walls cracked........the Southland sun would melt the roof offa the Chernobyl reactor.
Hey , it aint all bad , I just got 500 bucks for a pair of 18 year old Michelin motorbike tires ( 120-60-16 & 160-60-16 ). Guy is restoing an early 851 Ducati and wanted factory supplied tires to make it right .😁
My boat sits in a barn, out if the sun and weather, so my tires last for many more years. At first sign of cracking or not holding air, they get replaced. My last set went for almost 9 years before replacing them. No cracks, leaks or any sign of age at all, but decided to replace before selling the boat as I knew the new owner would probably not replace them because they looked so good.
JASinIL2006
Keeping the tires away from sunlight is key. Trailers kept outdoors will need tire replacements much more frequently.
cyclops222
We need a discussion today.
Have safer tires that last for decades. In any amount of sun light. Really ?
Passenger car tires. (y)
JimS123
ST tires have printing on the sidewalls that say, to the effect, "don't put these on a vehicle that carries passengers". What more need be said?
My son's 5 year old garage kept rig was on vacation and both tires literally disintegrated at 65 mph. It's not just UV. Keeping them at full pressure is also a must. That was NOT my son's problem. Chinacrap was part of it.
Most trailer tires are built cheap, unlike passenger tires. Even n cheap passenger tires are built better with better materials than trailer tires.
They still have a finite life. Discount tire won't touch any that are over 6 years old.
For most applications, you can't find an auto tire that has enough load capacity especially considering you need to de-rate an auto tire for trailer application.
That;s why I only use Maxxis or Goodyear Endurance trailer tires
JimS123
I don't remember if it was 15 or 20 years ago. Regardless, GY Endurance was crap back then. As I remember they were made in China, and had a bad rep.
I could be wrong, but buying ST tires has been a crap shoot for 40 years.
