timing adjustments For 1500 inline 6
urbanp
I read the Timing post by Clamscanino about adjusting the timing for inline 6 up to 88.
The only question I have about this is how to determine if my 1976 1500 is a direct charge" crossflow which requires 21 deg max advance or a plain crossflow which requires 34 deg max advance.
anyone familliar with this?
erniex
Re: timing adjustments For 1500 inline 6
"The "direct charge" motors appeared in 1970 and most have a sticker advertising such. All of them use the same 2.75 bore and piston with a funny "eyebrow" on top of it. The 402 and all the larger (than 50hp) inline 3's,4's,and 6's were direct charge through the 70's and 80's."
-W
The above quote was taken from Clams' thread, page 2.
I would say you have a "direct charge".
Hope this helps.
EE
urbanP, I have a '77 1500 Merc. It is identical to the '76, and is a direct charge model.
Clams Canino
Yes all the 1500's, 1350's, 1400's, and 1150's are direct charge.
-W
timmathis
21 degrees max advance. Is what you want to set it at.
Tim
urbanp
thanks everyone for all the help
