TN-28 gas/oil ratio and spark plug gap
greenygreen
TN-28 ...i have read several contradicting threads on t series johnson gas/oil ratio and spark plug gaps and i was wondering if there was a general consensus on these..
Re: TN-28 gas/oil ratio and spark plug gap
I believe the ratio is 16:1 and the plugs 0.030"
greenygreen
thats what i run, just wondering about some saying run 50:1 or 32:1 in these old motors
If someone says to use anything less the 16:1, they are talking thru the top of their head. These old engines used friction bearings(bushings) and need lots of oil to act as a cushion and prevent metal to metal contact.
