TNT draining battery
kaferhaus
The tilt and trim is somehow draining the battery rather quickly (with engine off of course). I've isolated it by disconnecting it from the fuse panel... the ampmeter then shows no drain... so it's definately in that circuit.
However that's about as far as my troubleshooting knowledge goes.... how do I find exactly which component is shorted?
btw it works fine...... go figure
Re: TNT draining battery
Ayuh,... Which of the 4 barges listed are you workin' on,..??
kaferhaus
Actually I have to update that list... the Twin Vee is no longer mine...
What I'm working on is a a 1988 48HP evinrude
