To Wood or Not to Wood?
keelbolts
Hi Gents,
I have just acquired a 1960 MFG Oxford hull that will need everything. They came with an aluminum C-channel keelson and stringers. Mine still has the keelson, but the stringers are gone. There is also a wooden "keel," running down the outside of the hull, that is probably bad on mine. I am kicking around the idea of going in with wood rather than trying to locate the proper aluminum channels to replace those that are missing.
I have 25 years of experience with sailboats, mostly wooden, but I'm in, for me, uncharted waters here. I have a few options that I'd like your input on:
Stringers cut from 2x's in place of the original three aluminum members. I'm already going to be into wood working on the bottom & the transom. Jim Anderson, in his book Runabout Renovation, recommends using pressure treated wood. In traditional wooden boat construction, PT wood is almost never used. It sounds like a fine idea, but are there problems with getting fiberglass/epoxy to bond to PT wood?
Another idea is to lay in a, sort of, egg-crate system in plywood or 1x's. That would certainly stiffen her up a good deal, but is it overkill. It's a 15' boat that I plan to use leisurely cruising rivers. It was rated at about a 15 to 25 or 30 HP engine and I have a tendency to over design stuff.
Thanks for your help.
Re: To Wood or Not to Wood?
Hi Gents,
Ayuh,... Welcome Aboard,... Yer in Good company here, 'n it sounds like yer comfortable with the task, 'n materials....
Epoxy bonds to P/T wood, without problem, So long as the wood is Dry...
Much/ most P/T, Ain't....
'n I agree with ya, a couple of simple wood stringers makes more sense than a modular egg crate system...
In this case, the Quick, 'n Easy beats out the Over-designed, hands down.... ;)
jigngrub
I agree with Bond-o, all the PT wood you'll find at lumber yards and home centers will be too wet for any type of resin application.
There is a kiln dried CCA pressure treated plywood manufactured specifically for marine applications, you can probably find it through a new boat dealer near you. They use it for pontoon decks and some aluminum boats as well as other marine applications.
