torque shift props
guylain
Re: torque shift props
hello i come back to cuba<br />I'm very sorry for my english, but i try to go better. Yes my cam BREAK (crack) and my pal go out of the hub. I thing to, my motor turn to hight. It's the raison for my question, if i go with 13-32 my RPM go down and this prop. is good for my application (Wellcraft elite 22 foot, 460 ford block 335 h.p.). I don't have any warning because i buy this prop. use. Thank you very much and don't look my fault in english.
Ok guylain,<br />If I understand Correctly,<br />Yes,<br />The Prop that will go to 32"s of pitch Should Lower your WOT, to get it down to a more reasonable level of RPMs......<br />If you're over-reving with the 26" pitch,<br />That Must be 1 Healthy 460..........<br /><br />Good Luck,+ Keep Posting................ ;)
