Torque?
Chief101
This is likely the best place to ask this. How much torque do I put on a lug-nut, the vehicle is a F250 and the wheels are 16.5. I replaced the tires and wheels the other day and came out with some squeaks. I went back and retorqued to 55.8# but havn't testdriven. Will this do? Thanks. Chief Chief
Re: Torque?
3/4 ton 8 lugs per wheel 85 ft lb at a minimum.<br /><br />Lug Size Ft/Lbs Torque <br />7/16" 55-65 <br />1/2" 75-85 <br />9/16" 95-115 <br />5/8" 135-145 <br />12mm 72-80 <br />14mm 85-95
Chief101
Re: Torque?
That sounds aboot riight Bob, I'll go tighten them up. Thanks, Chief Chief
