Tower of Power ... TODAY!!
IT FREGG'IN WORKS!!
..kinda I have the throttle agusted by the screws at the top the distrib. cap very top screw. It picks up speed in the water and moves more quick then it did. How ever now when i use my high idle to start it tries to shift into forward but not all the way just enough to jolt the boat and then back to nutrall. Not a good sound or feeling.. :confused:
Re: Tower of Power ... TODAY!!
It is time to perform a link and synch. Idle pickup timing and max spark advance must be set correctly or the motor will damage itself. There is a post on this. it is likely in the FAQ by now. I recommend you make it happen before you try to use the boat.
