Towing with Trolling Motor on?
DWavs
Hey all,
I picked up a small trailer for my 12' Jon Boat and was curious on whether it is ok to pull it with the trolling motor attached or should I attach it when I reach the boat landing? It is attached on the transom.
Thanks!
David
jestor68
Re: Towing with Trolling Motor on?
Consider it an electric outboard motor and trailer the same way.
If you are worried about it bouncing around, throw a bungie cord around the shaft so it won't, should not have any problem. I had a SS
cable wrapped around mine and padlocked in case of sticky fingers being around when I wasn't.
NYBo
I wouldn't leave it attached if towing a great distance. The vast majority of the weight is at one end, so bumps put a lot of stress on the transom bracket of the motor.
WIMUSKY
When I had a 14' with a transom mount trolling motor, I always removed it when traveling. Better to be safe than sorry.......
Barnacle_Bill
Your only talking a couple minutes to remove it. Be safe
GA_Boater
And only a couple of seconds to steal it if someone wants it bad enough. Even with cable and lock because they don't care about damaging anything. My two pennies.
