trailer electrical connector
tbird175
I have a 97 F 150 truck with a flat 4 wire connector for trailer hook up. The connector is bad and I plan to replace it. My two trailers do not have brakes. What type connector should I install? I have no problem replacing the trailer plugs.
If your not going to add brakes to your trailers then just replace the flat plug
GA_Boater
Replace the connector with what you have now. It works for your trailers, so why change?
redmen62
I agree, if you're not pulling anything with breaks just stick with flat 4 pin. Switching to a circular 7 or the flat 5 pin (similar to your 4 pin, but with a "break override" for surge breaks) would be a decent amount of work for not much gain.
