trailer hubs bearing .
dakotarmx
ok i bought this boat about 3 months ago the bearing buddies had a wrap of duct tape on them they were in rough shape .so i knocked them of put new ones first trip down the road they were gone ,so i blamed it on the cheap bearing buddies .bought another set .down the road ones gone got the jack out lifted it up grab the wheel and i can wiggle it back and forth pulled the cotter pin and tightend the nut a good 4 or 5 turns .:%:% same thing on the other side .dont get it maybe the guy before me was a dummy .how did they get that loose and have a cotter pin in them .
Pony
Re: trailer hubs bearing .
If you havent already, I would pull the bearings and take a good look at them. Sounds like he had the castle nut on pretty loose and the wheel slop could harm the bearings..........If he left them that loose, I'm willing to bet he didnt pack them with grease at installation correctly either.
I'm not entirely sure that is what is causing the bearing buddies to come off though. Usually they are pretty tight and take a bit of wiggling with a mallet and wood block to loosen. Are you sure you have the right size? Did you mic the i.d. of the hub to get an exact measurement? I might be wrong, maybe the wheel slop is enough to do it, I'd just want to know for sure before I bought new ones again.
dakotarmx
i agree pony im gonna swap the whole hub .new bearings the works .its kinda disturbing .i didnt think that wheel working in and out would push those bearing buddies of either .im sure they were right ones .they went on tight .i cant beleave somone left the nut that loose and put the cotter pin in .o well tear down start fresh thanks for the advice
jtexas
You have to look at those BB's every stop when you first get 'em on...as you have discovered, they can be off by an imperceptable amount, and they'll leave you first chance they get. Keep your rubber mallet in the truck so you can whack 'em. After they've been with you 50 or 60 miles without a whack, then you can count on 'em.
Or, I guess you could just wrap 'em with duct tape!
dakotarmx
good one j tex .there is a time for duct tape .we'll save that for last resort thanks for the tips
I have bearing buddie son my trailer.Last trip i was on I lost a wheel cause by lug studs that broke off. In the process, my buddy bearing was knocked off. Now that hub will not hold a buddy bearing. they will eventually fall off. I bought some Fulton versions and they stay on fine because they are slightly larger that the Buddy Bearing.
My hub opening must have gotten slightly enlarged by the wheel yanking it off. Maybe that is your situation as well.
