trailer springs
ed72vette
What is the diffrence in ride [or any other factor] on a 3 leaf spring set up compared to a 4 leaf spring all with the same weight rating?
Re: trailer springs
Ayuh,.......
Little or None.......
It's the weight Rating that'll Stiffen, or Soften the ride......
I'd venture to Guess,....
That a 4 leaf Might rot out quicker if you're launching in Saltwater.......
Maybe......
ed72vette
Re: trailer springs
Thanks for the info. This was my thought as well on the rot for the 4 leaf. I broke a 4 leaf after 3 season being dipped in saltwater. I ordered a 3 leaf to reduce the rot. I also increased the weight of the spring to 1750# from a 1250#, I hope that this not to much of an increase.
Ed
Re: trailer springs
Never heard of a 3 and 4 leaf spring being rated the same unless they had two different mounting configuarations.
As for the leaf count, you can look at it in 2 ways. The 3 leaf has less mass to rust but you also have less to rust before a failure occurs. You would think that the spring with the greatest mass would offer the longest life.
FWIW I still have the orginal 4 leaf #2100 springs on my 1997 trailer. They're still solid and I don't have any plans to replace them anytime too soon.
Always in salt and usually hosed off with freshwater after use.
External Combustion
Re: trailer springs
If both springs have equal weight rating then the four leaf spring will have a faster dampening rate. Sometimes this phenomena is used to get out of using shock absorbers. The ride will have less bounce with the four leaf spring.
jeeperman
Re: trailer springs
if the weight capacities of the springs are the same.....
The 3 leaf will last longer due to thicker leafs.
The 4 leaf will be a smoother ride because as weight is added more leafs will do the work instead of less leafs doing more work sooner.
The 3 leafer should be cheaper than the 3 leafer and usually found on the cheapest trailers as well.
The more leafs you have the more progressive the spring.
