Trailer winch question.
Dawg'sLife93
I have a Fulton T-something 2600# winch on my trailer. It's rusty and looks like crap. I am going to replace it. I need to make sure my math is correct before I order.
Boat- 3400 lbs dry
Fuel- 350-400 lbs
Stuff- 150 lbs
Lets call it 4000 lbs just incase. I have heard the standard is 35% of gross weight, I'm choosing to go 50% gross weight with a 2000 lb winch.
Is my math and figuring standard correct?
Also...
Cable or nylon strap?
It's a EZ Loader roller trailer.
Thanks Y'all.
RobWise64
Re: Trailer winch question.
Your math is correct. Boat, fuel, gear, etc divided by two = target winch capacity, according to Fulton's guidelines. Strap vs cable is a preference thing, but straps don't bind up in the winch, and are often rated for more weight than cables.
GA_Boater
Straps don't stick you when the strands break.
Dawg'sLife93
Thank you Sir!
Ain't that the truth!!!!
Converted to a strap about 5 yrs ago, not looking back, wise choice..
four winns 214
Stick with a Fulton winch. At the very least, stay away from SeaSense. They're also sold under house brand names like Bass Pro and others. I replaced my winch with a Fulton F2. Pricy, but commensurate quality, in my opinion.
Dawg'sLife93
I went with a Fulton F2 2k also. I found it for 105 and free shipping, then had a 20% off coupon. I just have to wait on it to get here like everything else. LOL
UncleWillie
I upgraded to the Fulton F2 - 3200#.
It is a two speed. 5:1 Normal Gearing, and 16:1 for when the going gets tough!
It is way overkill for a 3500# boat, but it makes winching so easy that the Admiral can crank it right up to the Bow Stop with one hand!
I found it on ebay, Brand New, in a very Distressed Box for $75 delivered. Just Lucky I guess!
