Transom Angle
Reel Kahuna
From where is the transom angle measured? From the top of the gunwale or from the bottom of the boat?
JimS123
Re: Transom Angle
The angle is the same whether its at the top or the bottom. The "measurement" is degress off vertical.
steelespike
Re: Transom Angle
Measure at the bottom.Use a carpenters square.Place the long side along the keel so the short side touches the transom measure the distance from the bottom of transom to the square.
Each 1/4" is 1 degree.Just post how to measure transom angle on google.
Measuring at the bottom gives a stable surface for the square to sit against.
Reel Kahuna
Re: Transom Angle
Thanks for the replies. I guess I should have known that but just had senior moment LOL
