transom Exaust
terrylee
I was wondering if would be costly to put the Exhaust through the transom. Can I use the manifolds I have now, how would I block off where the exhaust goes in to the out drive unit. It has a 4.3 v-6 with a alpha generation one outdrive just wondering. I love the way those exhaust sound but like my big family boat as well is there a way to have both. I was also told this would help the engine breath better and perform better.
thanks.......
Haut Medoc
Re: transom Exaust
Yes, but you will need new risers.....
You remove the y pipe & get a block off plate that they make for that....
thanks.......
There is a system called Captain's Choice, that allows you to do thru hull or exhaust through the prop....
I don't have a link, but I am sure someone will.....
No idea of the co$t.......:)
Manipulator
Re: transom Exaust
Corsa makes systems with captains call but you are talking some bucks. If you used mufflers it might not be too loud at idle speed. As you are moving on plane most of the sound is behind you so that really wouldn't be much of an issue. On a V6, personally I wouldn't bother. I don't want to ruin your day but its not going to sound like a V8. The V8 has that sweet rumble, a V6 would sound more like a weed whacker in my opinion. You would probably gain a few HP though.
Re: transom Exaust
Ayuh,........
I've got home made Thru Hulls on My 4.3LX,.......
I'd liken the Noise to more like a little Cessna airplane flying over head........
A real unexciting Drone is about Right..........
And,....... The performance Increase,........... It Ain't There.........;)
