Transom mount transducer max speed
DoctorCAD
My transom mounted transducer for an Eagle 168 depth finder has a pivot to keep you from tearing it off if you were to beach or hit debris. The problem I am having is that around 55 mph, it pivots up. Any way to mount differently or something. I realize 55 is way too fast most times, but if the boat can do it, I want to be able to go fast.
Re: Transom mount transducer max speed
Tighten the screw and nut that are the pivot point.
