transom plate
vxtech
1975 inline 6 mc drive, i have 49701 casting number on inside transom plate will mcm 79000 casting number transom plate fit in place of original plate
Re: transom plate
Ayuh,...
Casting #s are about the Worst way to ID a part...
Atleast here on the forum...
What did the 79000 Come From,..??
vxtech
Re: transom plate
seller says 1980 vintage 120 mercruiser alpha stern drive, also looking at my transom plate exhaust pipe opening it is more like a square with slight curve on the bottom, other plate forsale is more like a funnel shape for exhaust pipe ,angled sides narrowing to bottom
Re: transom plate
Ayuh,...
I'm not exactly sure of When,...
But,..
Sometime around that vintage, the rear motor mounts went from 15" on center to 9" on center...
vxtech
Re: transom plate
yeah the width is much wider than newer alphas models ,its just exhaust pipe opening has different shape when comparing the two, almost looks smaller than one i have because sides on my openiing are straight down and other one has angled sides for exhaust opening
