Transom rebuild questions
Doneysitdown
I've got an alpha 1 gen 1. Took my out drive to inspect it and found that my u joint bellows. had a little water in it. I've been reading and it sounds like it's time for a transom rebuild. Ie gimbal bearing, all the bellows and water hose. My question is if any one has used the sei, Sierra or other brand rebuild kits or just go with oem. Also tips on changing, what to look out for and special tools needed. Any other tips are appreciated. Thanks in advance
Bt Doctur
hinge pin tool or a 1/2 inch allen wrench, a good torch to loosen the loc-tite, 1/4 inch socket set and a universal joint
AND LOTS OF BEER
bspeth
Yes bellows adhesive.I like OEM,its all Ive used before and I didn't have a problem. The old race mounted on a 2x4 is a good bearing driver.Need alignment tool to line up the bearing for setting alignment. Use a pair of Wally world BBQ tongs with the ends bent 90deg out for exaust bellows.Trial fit to see how everything will go together before applying adhesive.
flipbro
I use blue loctite not red. I've also used auto weather strip adhesive 3m or permitex.
Doneysitdown
Thanks for the great input guys. Got my transom stripped all the way down. Still have to pull the gimbals bearing. I do have a question on shift shaft.
The shaft that goes through the exhaust passage, does that have a replaceable seal? It seems to me that the shaft has to much play in it
tmaranda
Woah, brilliant. Where were you last year when I was fighting with that darn thing??
achris
More fish than mountain goat
Only ever used one non-genuine bellows. Way too hard to get on compared to OEM... And adhesive is not optional, it's compulsory, both ends.
Chris........
You can also use a 3" such 40 PVC sewer pipe to drive the gimbal bearing on with, it's a good match to the beating OD.
Doneysitdown
No Title
Is this the right kit. Are they both right. I like the fact that the sierra kit includes a greaseable gimble bearing. However oem is best. What do the experts think?
Grub54891
I prefer the greaseable bearing, but oem bellows myself. I'm fortunate enough to be able to acquire bellows and bearing separately rather cheaply from my workplace.
achris
Nothing wrong with sealed gimbal bearings. Mine's 10 years old now and is no trouble. My old engine has sealed unis, 22 years and still going, over 2,000 hours. Don't know what this fascination with greaseable bearings is? Throw away the grease gun and be thankful for it I say.....
Chris.........
Rick Stephens
Chris.........
Sealed everything!
When they invented materials that would seal a ujoint or a bearing, we stopped having to spent 45 minutes greasing our cars and trucks every 6 months. Yeah! Grease zerk is dead. Long live the grease zerk.
Fishermark
True. My old 56 Chevy original owners manual calls for greasing everything something like every 1000 miles or something crazy like that.
With a newer car how many have ever greased anything at all?
I too like the sealed bearings.
bspeth
Chris,in #11 did you mean that you have only used non-OEM once?
achris
Correct. Found it so hard to get on I ended up tossing it in the bin and using genuine. It was a Sierra too.
