Transom Replacement Cost
gdmarsh
I have a 16' Aluminum Fisher Marsh Hawk. I have been told by two different people when I had boat in for motor repair that I need the transom replaced. Wondering if someone can tell me an approx. cost of taking it in to be replaced.
SWD
Re: Transom Replacement Cost
Just get a quote at your local marine repair place...it will be more up to date than what we would say.
Do it your self for about $100
I will move this to restoration where they are being replaced all the time and the aluminum boat ones are the easiest.
jbcurt00
Post a pix of what an Aluminum Fisher Marsh Hawk transom looks like. Never seen 1 but as Bob said, tinny transom's are usually much easier then a fiberglass boat's.............
eboat85
I ran into the same thing and with the help of this crew I have been plugging away at it and should have it all done for under $200. Granted, I will be doing some upgrades along the way so it might cost you less but when it is done I will have confidence that it will be right.
pckeen
Your marina can tell you - lots of labor in a job like that. If you are interested in doing it yourself, take a look at this jetstar youtube series of videos. It explains it well. In addition, if you search transom replacement on iboats, you'll find lots of information here.
https://www.youtube.com/watch?v=NSs_aNY6mwU
Good luck!
still afloat
How hard any aluminum boat transom is will depend on whether the transom is trapped by welded panels or just bolted to the inside of the transom and capped.
I've done a few that took only an hour or so and others that took all weekend to replace.
If I recall correctly, the Marsh Hawk was all an all welded hull, so getting at the inner wood core may be an issue if they welded the inner panels over top of the wood.
kfa4303
Banned
+1. $100 is usually more than enough to buy the materials. You really only need one sheet of 3/4" non-pressure treated, exterior grade plywood, some sealant (epoxy or spar urethane), a tube of 3M 5200 marine caulk, and some stainless steel hardware. You can get everything you need, except epoxy, from Lowes/HD. If you have a West Marine nearby they will carry the epoxy should you choose to use it.
thejudester
What is a good estimate to repair/replace the transom on a 21 ft. 1988 Four Winns.
Is it worth doing if I cannot do any of the work myself.
Boat floor and sides were replaced with marine grade materials 3 years ago.
Engine overhauled 3 years ago just before we bought it. (Saw pics and have receipts).
No problems since we bought it other than the starter needed to be replaced this summer.
If I cannot afford to fix it, would I be able to sell it as is AND if so for how much??? Your best guess please.
I would tell the buyer about the transom problem. 3 summers boating and loving it big time.
Woodonglass
It's best to start your own thread concerning your boat. To answer your question it's usually not worth it to pay a shop to replace a transom. A good Guess-Ti-Mate for an I/O Transom replacement for this boat would be IMHO approx. $4000 dollars U.S. I seriously doubt you could re-coup your money. As she sits with a bad transom but with a good power plant and the hull and interior in good shape Maybe $1 to 2 Thousand. Maybe. It's very hard to say. Used Boats with Bad Transoms are VERY Plentiful!!!
jbcurt00
Jude: You're asking about a large 21ft I/O fiberglass boat transom in a small 16ft aluminum OB boat thread, 2 totally different types of boats.
If the transom needs replaced, there may be further damage, even if 'only' 3yrs old. You will probably be removing a portion of that 3yr old deck (or sole, but not really a floor) that was replaced, and possibly the side panels (if they are resting on the deck, they may have to come off to remove the deck)...........
Start a thread about your 4Winns, post some pix of your boat. You'll get a few opinions. Here's mine:
It's a 1988 boat, that's 25yrs old. It may be a great boat, but it's still a 25yr old boat. Unless you WANT to work on a boat, I doubt you'll find much motivation for doing the transom repair. It isn't easy, its labor intensive & will take a good long while. It will take you several months of weekends & nites to pull this boat apart & put it back together. It will likely cost you several thousand dollars to accomplish your goal.
If there were no problems other then a starter, why does the transom need to be replaced. Good to go boats, that have had adequate repairs of the deck, should have included a thorough inspection of the transom. Most boats this age, that need 'some' transom or deck repairs, need much more work then originally expected.....
gdmarsh: No pix or further info?
thejudester
Many thanks. As we are not able to fix this ourselves we will definitely not be taking it to a shop. As the other poster said " It is 25 years old", our thanks for reminding us of that. I did get an estimate from a fellow boater who said it would be in the $4000. range. Thanks for the confirmation. I would have started my own thread, however, I was not sure how to do so? Glad you found me on this thread.
